Add Ports to an MLT LAG
Perform this procedure to add ports to an MLT LAG.
Add port 1/24 to MLT 40:
Switch:1(config)#mlt 40 member 1/24
Use the data in the following table to use the mlt command.
Variable |
Value |
enable |
Creates and enables a new MLT. |
encapsulation dot1q |
Enables trunking on the MLT. |
member {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Adds ports to the MLT. Identifies the
slot and port in one of the following formats:
<1-512> |
Specifies the MLT ID. |
name WORD<0-64> |
Configures the name for the MLT. |
private-vlan {isolated|promiscuous|trunk} |
Specifies a private VLAN type for the MLT. |
vlan <1-4059> |
Specifies a VLAN ID to add to the MLT. |
